How do I use standalone toolchain to build uboot without yocto?
1,258件の閲覧回数
muaxi8
Contributor V
《QorIQ SDK 2.0 Documentation For QorIQ Processors》
3.3.13  There is a toolchain compile for the kernel,I wonder if there is a toolchain compile method for the uboot instead of a Yocto compiler ?
1,253件の閲覧回数
jimmychan
The standalone toolchain to build u-boot is basically same as the method of standalone building kernel. Steps 1-3 are same. Then go to u-boot source dir, then "make" the source code.
