Errors while compiling SDK 2.0 for T1040
1,783 次查看
Suraj_Prakash
     I am using SDK2.0 for T1040RDB since a long time. The SDK used compile smoothly but recently it is throwing the following error while compiling. Kindly please suggest a solution
bitbake fsl-image-minimal
WARNING: Host distribution "Ubuntu-20.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |#########################################################################################################| ETA: 00:00:00
Loaded 6119 entries from dependency cache.
WARNING: No recipes available for:
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-cgl/meta-cgl-common/recipes-extended/openipmi/openipmi_2.0.21.bbappend
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version 2.7.9 of python not available (for item python)
NOTE: versions of python available: 2.7.18
NOTE: preferred version 2.7.9 of python not available (for item python-shell)
NOTE: preferred version 2.7.9 of python not available (for item python-io)
NOTE: preferred version 2.7.9 of python not available (for item python-math)
NOTE: preferred version 2.7.9 of python not available (for item python-crypt)
NOTE: preferred version 2.7.9 of python not available (for item python-logging)
NOTE: preferred version 2.7.9 of python not available (for item python-fcntl)
NOTE: preferred version 2.7.9 of python not available (for item python-subprocess)
NOTE: preferred version 2.7.9 of python not available (for item python-pickle)
NOTE: preferred version 2.7.9 of python not available (for item python-compression)
NOTE: preferred version 2.7.9 of python not available (for item python-textutils)
NOTE: preferred version 2.7.9 of python not available (for item python-stringold)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pickle)
NOTE: versions of lib32-python available: 2.7.18
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-crypt)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-shell)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-fcntl)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-stringold)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-logging)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-subprocess)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-math)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-compression)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-textutils)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-io)
NOTE: preferred version 2.7.9 of python not available (for item python-2to3)
NOTE: preferred version 2.7.9 of python not available (for item python-argparse)
NOTE: preferred version 2.7.9 of python not available (for item python-audio)
NOTE: preferred version 2.7.9 of python not available (for item python-bsddb)
NOTE: preferred version 2.7.9 of python not available (for item python-codecs)
NOTE: preferred version 2.7.9 of python not available (for item python-compile)
NOTE: preferred version 2.7.9 of python not available (for item python-compiler)
NOTE: preferred version 2.7.9 of python not available (for item python-contextlib)
NOTE: preferred version 2.7.9 of python not available (for item python-core)
NOTE: preferred version 2.7.9 of python not available (for item python-ctypes)
NOTE: preferred version 2.7.9 of python not available (for item python-curses)
NOTE: preferred version 2.7.9 of python not available (for item python-datetime)
NOTE: preferred version 2.7.9 of python not available (for item python-db)
NOTE: preferred version 2.7.9 of python not available (for item python-debugger)
NOTE: preferred version 2.7.9 of python not available (for item python-difflib)
NOTE: preferred version 2.7.9 of python not available (for item python-distutils)
NOTE: preferred version 2.7.9 of python not available (for item python-doctest)
NOTE: preferred version 2.7.9 of python not available (for item python-elementtree)
NOTE: preferred version 2.7.9 of python not available (for item python-email)
NOTE: preferred version 2.7.9 of python not available (for item python-gdbm)
NOTE: preferred version 2.7.9 of python not available (for item python-hotshot)
NOTE: preferred version 2.7.9 of python not available (for item python-html)
NOTE: preferred version 2.7.9 of python not available (for item python-idle)
NOTE: preferred version 2.7.9 of python not available (for item python-image)
NOTE: preferred version 2.7.9 of python not available (for item python-importlib)
NOTE: preferred version 2.7.9 of python not available (for item python-json)
NOTE: preferred version 2.7.9 of python not available (for item python-lang)
NOTE: preferred version 2.7.9 of python not available (for item python-mailbox)
NOTE: preferred version 2.7.9 of python not available (for item python-mime)
NOTE: preferred version 2.7.9 of python not available (for item python-mmap)
NOTE: preferred version 2.7.9 of python not available (for item python-multiprocessing)
NOTE: preferred version 2.7.9 of python not available (for item python-netclient)
NOTE: preferred version 2.7.9 of python not available (for item python-netserver)
NOTE: preferred version 2.7.9 of python not available (for item python-numbers)
NOTE: preferred version 2.7.9 of python not available (for item python-pkgutil)
NOTE: preferred version 2.7.9 of python not available (for item python-pprint)
NOTE: preferred version 2.7.9 of python not available (for item python-profile)
NOTE: preferred version 2.7.9 of python not available (for item python-pydoc)
NOTE: preferred version 2.7.9 of python not available (for item python-re)
NOTE: preferred version 2.7.9 of python not available (for item python-readline)
NOTE: preferred version 2.7.9 of python not available (for item python-resource)
NOTE: preferred version 2.7.9 of python not available (for item python-robotparser)
NOTE: preferred version 2.7.9 of python not available (for item python-smtpd)
NOTE: preferred version 2.7.9 of python not available (for item python-sqlite3)
NOTE: preferred version 2.7.9 of python not available (for item python-sqlite3-tests)
NOTE: preferred version 2.7.9 of python not available (for item python-syslog)
NOTE: preferred version 2.7.9 of python not available (for item python-terminal)
NOTE: preferred version 2.7.9 of python not available (for item python-tests)
NOTE: preferred version 2.7.9 of python not available (for item python-threading)
NOTE: preferred version 2.7.9 of python not available (for item python-tkinter)
NOTE: preferred version 2.7.9 of python not available (for item python-unittest)
NOTE: preferred version 2.7.9 of python not available (for item python-unixadmin)
NOTE: preferred version 2.7.9 of python not available (for item python-xml)
NOTE: preferred version 2.7.9 of python not available (for item python-xmlrpc)
NOTE: preferred version 2.7.9 of python not available (for item python-zlib)
NOTE: preferred version 2.7.9 of python not available (for item python-misc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-re)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-lang)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-core)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pprint)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-netclient)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-audio)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-image)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-mime)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-zlib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-datetime)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-threading)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-sqlite3)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-tkinter)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-codecs)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-distutils)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-difflib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-contextlib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-xml)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-netserver)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-ctypes)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-mmap)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-debugger)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-unittest)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-email)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pkgutil)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-bsddb)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-sqlite3-tests)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-db)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-doctest)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-curses)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-idle)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-misc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-hotshot)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-json)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-profile)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pydoc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-mailbox)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-elementtree)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-gdbm)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-resource)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-compiler)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-xmlrpc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-html)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-2to3)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-syslog)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-compile)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-tests)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-unixadmin)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-smtpd)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-terminal)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-readline)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-importlib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-argparse)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-robotparser)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-multiprocessing)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-numbers)
Build Configuration:
BB_VERSION = "1.28.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-20.04"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "t1040d4rdb-64b"
DISTRO = "fsl-qoriq"
DISTRO_VERSION = "2.0"
TUNE_FEATURES = "m64 fpu-hard e5500"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "HEAD:9a211a4a2c1bfcb292dc97d8dcac149bca9e3f1b"
meta-cgl-common = "HEAD:a8a7d8112ac8eb02c5752780dad001ce322291b2"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-xfce = "HEAD:dc5634968b270dde250690609f0015f881db81f2"
meta-freescale = "HEAD:7facbdb726e2dda0515e084c2066a4b8dd99c6d2"
meta-freescale-internal = "HEAD:4829293f807e35a1111e79763294fc8b98b97810"
meta-freescale-extra = "HEAD:bee911b027e0480b034674d0ddee3fcb06d2e985"
meta-virtualization = "HEAD:042425c1d98bdd7e44a62789bd03b375045266f5"
meta-java = "HEAD:8b776ac68f9af4596be3824152bcf0bc6b67fa1d"
meta-openstack
meta-openstack-aio-deploy
meta-openstack-compute-deploy
meta-openstack-compute-test-config
meta-openstack-controller-deploy
meta-openstack-controller-test-config
meta-openstack-qemu
meta-openstack-swift-deploy
meta-cloud-services = "HEAD:d8bc0d92d0f741e2ea1e6d3d9bc6b7a091d03cfb"
meta-security = "HEAD:f9367e71f923fc7d2fb600208e2b97535ea41777"
meta-nxp-npi-1701 = "jethro-sdk-v2.0-ga-1701:11975eebce9096a3567d00ba2067a2dbd2ed4d5c"
NOTE: Preparing RunQueue
WARNING: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_4.1.bb.do_compile is tainted from a forced run
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
No currently running tasks (1498 of 1500)
No real function for mknod: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknod
No real function for mknodat: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknodat
No real function for mknodat: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/../libWARNING: No not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: real not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: function not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: for not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: mknod: not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: undefined not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: symbol: not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: mknod not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: mknodat: not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
WARNING: mknodat not found in the base feeds (t1040d4rdb_64b ppc64e5500 powerpc64 noarch any all).
ERROR: Unable to install packages. Command '/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/smart --log-level=warning --data-dir=/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/fsl-image-minimal/1.0-r0/rootfs/var/lib/smart install --attempt -y ' returned 1:
error: no package(s) given
ERROR: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/fsl-image-minimal/1.0-r0/temp/log.do_rootfs.34837
ERROR: Task 7 (/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-fsl/images/fsl-image-minimal.bb, do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1499 tasks of which 1498 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 39 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
1,775 次查看
yipingwang
Did you upgrade your build host recently?
Please refer to the following topic,
https://yocto.yoctoproject.narkive.com/onEYhB40/pseudo-native-no-real-function-for-mknod
this issue was fixed with a patch in poky master with commit e090775f7e in May.
Please refer to the following patch
poky - Poky Build Tool and Metadata (yoctoproject.org)
