maximum limit of returning the license is reached
已解决
跳至解决方案
1,424 次查看
shalakashinde
I have QCVS license purchased.
Its the floating license.
I couldn't set it up as a floating license, hence it used to stop working once my ip address gets changed.
So I used to return it every time on NXP account and then set it up again.
Can you please help me overcome this issue and set it as a floating license to some server?
Thanks.
标签 (1)
1 解答
1,282 次查看
TomasPaez
Default returning actions are limited to 10 changes. On some NXP products this is extendable to a higher number thru a support case. I have extended this for your PEA-QIQ-OPTP-FL product, now you should be able to perform returns and rehost again.
Hope this helps
在原帖中查看解决方案
1 回复
1,283 次查看
TomasPaez
Hope this helps
