extend my CodeWarrior Evaluation problem
3,352 次查看
muaxi8
i want to extend my  CodeWarrior Evaluation licese, I did it according to the steps you provided. The steps in the following figure are shown. but i did not found "Renew Expired Software" option...
Below is a screenshot of my operation
.Click on My NXP from the top right menu;
Click on the link called Software Licensing and Support
but but,it jumps the below page. there is no "Renew Expired Software" option....why?  What did I do wrong
3,344 次查看
lisettelozano
I have extended the expiration date in the system. Please go ahead and generate the license again:
  1. Go to www.nxp.com.
  2. Log in to My NXP using your registered member ID and password.
  3. Click on Software Licensing and Support.
  4. If you are a member of multiple accounts, you will see a page where you need to select the account where the product you wish to license is hosted, and then your Product Information page will appear. If you are member of only one account your Product Information page will appear right away.
  5. Select the suite from which you need a license.
  6. A second Product Information page will appear. Select the product for which you need a license.
  7. Read and accept the Software Terms and Conditions.
  8. Click on the License Keys tab.
  9. Check the license files available and click the "Generate" button to assign the host information.
  10. Complete the license host information fields and click the Generate button again.
  11. The View Licenses page will appear with the content of your license.
  12. Click the "Save All" button and save the license file to the appropriate location.
Paulina
3,312 次查看
Piet123
3,345 次查看
lisettelozano
Paulina
