I uninstalled and reinstalled the latest CodeWarrior from the NXP site, now under Help there is no License selection. I registered a node locked license for basic version.
Solved! Go to Solution.
You need to get your license file from nxp.com
1. Log in
2. Go to SW Licensing & Support
3. Look for your CW Version
4. Generate the license.dat / certificate assigning your host ID
5. Copy the file in the app location,
Check this video with more information, hope this help
1. Log in
License.dat file needs to be loaded in the following directory
C:\Freescale\CW MCU v10.6\MCU
I see you have an evaluation entitlement that expired on 06/03/2016
Do you need to extend this ?
regards
I updated Code Warrior to the latest offline download. Under the Help menu, I do not see the Freescale Licenses. Does it supposed to be there?
Don
