Rehosting Codewarrior License Does not work
1,071 次查看
rob18767
I use Codewarrior 8.2.3 for developing existing product however I cannot get the licence.dat file to work on another machine.
I follow the instructions on the pdf given at
How to rehost CodeWarrior suite license
However after I generate and save the file I get the following error when attempting to run Codewarrior.
869 次查看
TomasPaez
I check the system and see you have license locked to
Ethernet Address: XXX3FF189D10
Is this the correct Ethernet Address?
The error shows the system is no able to see the license.dat file, OS
This product is a 32-bit application. To install and use it on Windows 7® 64-bit machines, see the white paper, “Installing CodeWarrior Classic on Windows 7 (64-bit) “ in the Featured Documentation section.
http://cache.nxp.com/files/soft_dev_tools/doc/app_note/AN3936.pdf?fsrch=1&sr=4&pageNum=1
In order to share your license information I invite you to create a case in out private community
1) Go to http://www.nxp.com/support/sales-and-support:SUPPORTHOME.
   2) On the bottom of the page under Submit New Issues, click Hardware & Software.
   3) Register with your business email to access NXP technical online support.
   4) A verification email will be sent to your account. Click the link embedded in that email to verify your access.
   5) On the NXP online support page, select Contact Support from the top menu and click “submit a new case” to start the process.
870 次查看
TomasPaez
