Question of the floating license
2,133 次查看
typhon14
Hi all,
I have 10 separate CodeWarrior floating licenses for same processor(MSC8156).
Is it possible that I want to run them on one license server simultaneously?
Additionally, I want to know the method of setting on 10 client PCs.
Thank you in advance.
Benson
1,844 次查看
J2MEJediMaster
Specialist I
First, you want to look at the Licensing FAQ web page for more information on floating licenses. You should be able to use one license server to manage the 10 clients. If the information there is not adequate, then enter a service request for a license issue.
---Tom
1,845 次查看
J2MEJediMaster
Specialist I
---Tom
