Perpetual license problem
2,836 次查看
Tgomes
A few months ago bought a perpetual license, but the CodeWarrior (10.1) does not recognize the file "license.dat". This file has been changed several times, but the problem persists. Anyone ever had or currently has a similar problem?
2,485 次查看
Tgomes
The problem was solved. A new license file was generated with the help of technical support from Freescale, and this time the file worked perfectly.
Regards.
5 回复数
2,485 次查看
c0170
Senior Contributor III
Hi Tgomes,
you posted your problem to the wrong section. People should be able to help you in Codewarrior section.
MartinK
2,485 次查看
Tgomes
MartinK,
You're right, I will move the problem. Thank's..
2,485 次查看
admin
Specialist II
Hi Tgomes,
If you still have a licensing problem, please email license@freescale.com for help.
Thanks!
Lee
2,485 次查看
Tgomes
Lee,
I filled out a service request a few days ago, but I'll also send an email, as you suggested, thanks for the help.
Tgomes.
2,486 次查看
Tgomes
Regards.
