Is it possible to access floating licence through VPN?
1,184 次查看
francisthiffaul
Hi, I'm using software Freescale CodeWarrior 7.1 with a floating licence installed on a local licence server. I need to emulate my code at customer office... So, there is it a way to access this floating licence from my customer office through VPN? We tried it and it doesn't seem to work, there is it a particular setting that should be done?
Thanks in advance for your support,
Francis
890 次查看
TomasPaez
Yes it is possible as long as you have access to server.
if there is any TCP/IP port closed make sure 27000-27009 range is open since these are the default range used.
You can also specify this on the license file
SERVER servname 00145MACETHC9A [portnumber]
USE_SERVER
DAEMON metrowks
891 次查看
TomasPaez
USE_SERVER
DAEMON metrowks
