How to use the floating license with another computer which is not connected with my office server ?
1,381 次查看
sivakumarananth
Hi Everyone,
        I am using a floating license for using the MQX RTOS  with Code Warrior IDE. We have got the license for one year and still 8 months are available.
My Doubt is ,
  • We are using the license by keeping it in the office server. The Clients are systems that are used by us for development.
  • Now I need to use my codewarrior with license in my home for further development, when i am not in office.
  • How to use the licensed version in my home without disturbing the one in office, FYI my home is connected with internet ?
Please provide me the procedure for accessing the license in my home ..
Siva Kumar A
692 次查看
trytohelp
Hi Kumar,
The Borrowing is a solution.
However if you can ping your server from your home you should be able to access the floating license too.
Probably you're using a VPN.
In this case you must add a port for the daemon too and access the license with the environment variable:
      LM_LICENSE_FILE=port-daemon@host
An Example of license used:
SERVER my_server 000111111111  27000
VENDOR metrowks port=1063
Where:
27000 is the port of license.
1063 is the port for deamon.
Most of the time the floating license must be checked via the LM_LICENSE_FILE environment variable.
By default we used port@host which is
      LM_LICENSE_FILE=27000@my_server
If this is not running (case of VPN) you can try the port-daemon@host which is:
      LM_LICENSE_FILE=1063@my_server
In some case my_server can be used by the SERVER_IP address.
I know in some cases this solved the problem too.
So this could
      1063@10.192.22.140 or 27000@10.192.22.140
Pascal Irrle
692 次查看
ZhangJennie
hello Siva Kumar A,
I suggest you use your license BORROW feature.
See attached document, section "FLEXlm using Borrowing"
Hope this helps!
this answer is for you. if it helps, please click on "correct answer " button. thanks!
Zhang Jun
