How can I add two products to one license file?
已解决
跳至解决方案
1,518 次查看
franklombardo
I am in the process of porting an application from Classic CodeWarrior to CodeWarrior for MCU Eclipse.  I would like to run both IDEs while I do this.
标签 (1)
1 解答
1,443 次查看
franklombardo
I have resolved my issue.  I don't know if there is an easier way to do it, but here is what I ended up doing.
I generated the license file for the two products, then copied the INCREMENT section(s) from the second file into the first. The combined file now works for both products from my single license server.
在原帖中查看解决方案
2 回复数
1,442 次查看
TomasPaez
Here is a document for combining license.
1,444 次查看
franklombardo
