CodeWarrior floating licenses - how to know if all available licenses are in use?
1,378 次查看
gorakk
It appears that if all available floating licenses are in use by other users, CodeWarrior will give the following error message when trying to build a project:
"Size of the application has exceeded the capability of this license. Contact your authorized distributor or Freescale to purchase a full version of the tools."
Is that what is expected?  Not a more explicit message?
Allen
We are using CodeWarrior 10.5
标记 (2)
932 次查看
trytohelp
Hi Allen,
When you want to build a project or a file, the tool contacts the server.
If a license is free, the tool will use it else it will work as Special Edition.
So if all licenses are used and your file exceed the Special Edition limitation you will get this type of message.
The real message is captured by the log file on the server:
    -4 Licensed number of users already reached.
Pascal Irrle
933 次查看
trytohelp
Hi Allen,
Pascal Irrle
932 次查看
gorakk
Thank you!  =)
