Code Warrior - Floating license server fails to serve licenses
1,063件の閲覧回数
jselfors
I'm trying to use Code Warrior with a floating license, and have setup my license server, which reports it as loading fine but when I attempt to connect to it with Code Warrior on the same machine I get error code LM_NOSERVSUPP on every license.
E.g. in my server log I see, which as far as I can tell should mean that the server properly loaded the license files:
9:55:13 (metrowks) Server started on <hostname> for: FSLTAP
9:55:13 (metrowks) PE_SCENARIOS REMOTEDEBUG ARMv7DBG
9:55:13 (metrowks) CMSISDAP
I have a ticket out to NXP support however I have not yet received a response there.
Thank you,
John
0 返答(返信)
