Hello Sheela,
It seems the key for IDE is missing or wrong.
To solve the problem I recommend you to edit your license file and add the following lines:
FEATURE Win32_CWIDE_Limited metrowks 5.5 permanent uncounted \
00E825C5615A HOSTID=ANY TS_OK
#### CW HC12 v5.1 license
INCREMENT Win32_CWIDE_Unlimited metrowks 5.900 permanent uncounted \
C10A4505A261 VENDOR_STRING="CodeWarrior IDE 4.2 or later, \
Windows" HOSTID=ANY ck=134 TS_OK
INCREMENT ProcessorExpertHCS12 metrowks 1.001 permanent uncounted \
3DBC1127AF17 VENDOR_STRING="Basic \
beans;1880BA310687F4EDA26BE3E59EB4D4E0" HOSTID=ANY ck=64 TS_OK
This is the standard special Edition license file.
If you will still have a problem, you should have the keys for:
Win32_CWIDE_Limited
Remove the keys and keep these ones only
Pascal
NXP Technical Support
