About CodeWarrior Ordering Questions?
1,021 次查看
ericliao
If you want to order CodeWarrior Professional Edition some questions please provide some suggestions, thanks ~ ~
(1) whether the original CW-HCS12X has expired in 2015-06-18, can you use the upgraded version (renewal) price or to re-purchase?
(2) if you can renew, how to renew?
Previous order information is as follows:
标记 (2)
930 次查看
stanish
Hi Eric,
I'm not quite sure I understand why you want to re-purchase.
Seems you have two permanent CodeWarrior Professional Suites already activated.
Permanent means the license itself does not expire.
The expiration you observe (Jun/18/2015) is the support certificate which is valid one year after the activation.
So if you'd like to renew support contract please check this video:
How to renew your Software|NXP
Anyway if you are interested in CW for HC12 license only then the license you have (assume v5.x) should work with the latest available release which is v5.2.
Hope it helps.
Stan
