How to merge several license files in 1 file?
I’ve created 2 videos showing/explaining how to generate a license file for several products in same time.
The doc explains the process to:
- Download multiple NL license files for different products based on 1 registration
- Download multiple Floating license files for different products based on 1 registration and how to merge them in 1 file.
If you have several floating registrations and want to merge the license files in one file, the process is similar to 2.
You must copy all license files in 1 file and keep only the first 3 server lines.
The other must be commented by adding a # as explained above.
