quiry about removing NHS3152 chip from demo PCB and purchasing pre-loaded chips
573件の閲覧回数
JourneyUh
Dear NXP Support Team,
I am currently conducting research using the NHS3152 chip and have successfully loaded firmware onto the chip using MCUXpresso. I would like to know:
  1. Is it possible to safely remove the NHS3152 chip from the demo PCB after firmware loading, and reuse it in another custom setup or substrate?
  2. If not, is it possible to purchase NHS3152 chips that are already pre-loaded with specific firmware?
Our research aims to transfer the chip to a different substrate for biocompatibility testing. Therefore, detachable or pre-programmed options would be highly beneficial for our work.
I look forward to your guidance or a direct contact point within the product team.
タグ(1)
553件の閲覧回数
EduardoZamora
Hello @JourneyUh,
Hope you are doing well.
Could you please kindly clarify what you mean by "biocompatibility testing"? Please consider that our support scope is mainly aimed to technical aspects and functionality of the device.
Documentation supporting this device can be found in NHS3152 product page, and inside the NHS3152 SDK that is available for download.
Eduardo.
