what is the common sensors used in robots?
2,841 次查看
xiaoye
Robotic sensors are used to estimate the status and environment of a robot. Sensors enable robots to comprehend and quantify the geometric and physical qualities of objects in their surroundings, such as location, orientation, velocity, acceleration, distance, size, force, moment, temperature, brightness, weight, and so on.
2,834 次查看
JozefKozon
Dear Xiaoye,
thank you very much for the information. Do you have a question?
With Best Regards,
Jozef
2,835 次查看
JozefKozon
Dear Xiaoye,
With Best Regards,
Jozef
2,647 次查看
xiaoye
Dear JozefKozon
Thanks to your reply. I want to know if I want a robot baby, what need I must to know and to do.
