to wakeup NTM88 from stop1 mode only if the acceleration value crosses its threshold value?
ソリューションへジャンプ
1,608件の閲覧回数
ankit2631
I am using NTM88 ic with single axis accelerometer on X-axis. currently by referring to example code NTM88_GenFSK_Beacons i am waking it up from stop1 mode every 30 sec interval and then compare the measured acceleration value with the threshold value, if it has crossed the threshold it wakes up and take the remaining measurement. but i dont want my NTM88 to wake up periodically after every 30 secs. i want it to wake up only if the threshold value of acceleration is reached. is this possible.?
1,591件の閲覧回数
TomasVaverka
Hi Ankit,
Unfortunately not.
Tomas
3 返答(返信)
1,597件の閲覧回数
TomasVaverka
Hi Ankit,
Unfortunately the NMT88 does not allow to set a certain acceleration threshold to wake it up when an acceleration exceeds it.
Tomas
1,595件の閲覧回数
ankit2631
if not acceleration then can we have interrupt on Temperature or pressure values.
1,592件の閲覧回数
TomasVaverka
Hi Ankit,
Unfortunately not.
Tomas
