stability to pressure cycle
1,222件の閲覧回数
masahirokiniwa
About MPXV4006, it has stability to 1.5 milion pressure cycles as below.
I think that its pressure cycle is gotten by adding full swing pressure.
When I use at environment of 0.6kPa pressure (10% of specification) cycle, how many pressure cycles does it have?
If it have a calculation formula, could you tell me it?
M.KIniwa
2 返答(返信)
1,016件の閲覧回数
TomasVaverka
Hi Masahiro,
Unfortunately, we do not test intermediate values you are asking about. The offset stability in this case is a statistical value and I would expect no change in its value at 10% of the sensors range.
Tomas
1,016件の閲覧回数
masahirokiniwa
Hi Tomas,
Thank you for your answer.
I see about its value.
M.Kiniwa
