representation of 0.1μT/LSB in millivolt (e.g. sensor's ADC output)?
2,151 次查看
walidbalid
Hello-- FXOS8700CQ has a Full Scale Range ±1000 μT and the sensitivity is 0.1μT/LSB. How can I calculate the output in milliVolt (e.g. sensor's ADC output)?
1,579 次查看
TomasVaverka
Hi Walid,
I am not really sure what you mean. Can you please elaborate a bit more your question?
Tomas
1,579 次查看
walidbalid
I would like to know the sensitivity as unite mV/uT or mV/V/gauss instead of uT/LSB. The relationship between Sensor output (mV) vs applied magnetic field. Actually in analogue sensors the sensor output, which is the resistive bridge output, is given in mV (Check Figure 2/pg.6 > http://stevenengineering.com/Tech_Support/PDFs/31MAGSEN.pdf). As for FXOS8700CQ, it has ADC unite that converts the analogue voltage at the resistive bridge output into digital given in uT. I would understand this relationship so that I can graph the sensor output as mV vs. time instead of uT vs. time.
