mpc5748g i2c
mpc5748g i2c
2,388件の閲覧回数
dingle
Hello,I'm using mpc5748g to learn.Now I try to operate LM75BD by i2c,but I don't know how to select module clock.Please give me some advice.
2 返答(返信)
2,199件の閲覧回数
david_diaz
In regard with the addressing, the LM75B slave address on the I2C-bus is partially defined by the logic applied to the device address pins A2, A1 and A0. Each of them is typically connected either to GND for logic 0, or to VCC for logic 1.
So, based on your A0-A2 pins configuration, the address will be composed as follow:
The complete protocol for writing and reading the registers are mentioned on the chapter 7.10 from the datasheet.
Please let me know if you have any further question.
David
2,197件の閲覧回数
dingle
Hello
When I'm suing S32 to study mpc5748g,It needs uncensorpassword.But I don't know how to get this?And how to enter password in GDB.Please help me in detail.Thank you very much.
