lock and unlock FXLS9xxxx on DSI
zssimon
Hi All,
can you please give sum support in the following questions?
I am using DSI interface
1. once configuration is done on the FXLS9xxxx dual axis accelerometer, how can I lock the setting? (OTP lock, not to allow user to change configuration)
2. once sensor is locked, how to unlock?
3. if a module is locked, is there any special initialization required to read out acceleration signals?
diazmarin09
Hello zssimon,
Please accept my apologies for the delayed response.
Once a region is written using the OTP Write sequence, the LOCK_Uxx bit in the appropriate CRC_xxx register is automatically set, locking the array from future writes. Register values in a region can be over-written using register write commands, but no new values can be written to the OTP.
If a region is locked, the value will always be reset to the OTP array value after a reset.
I do recommend contacting your sales representative as this feature is related to the factory programmed OTP configuration.
I hope this information helps.
David
diazmarin09
Hello zssimon,
I hope all is great with you. Thank you for using the NXP communities.
I am looking for such information internally. We will do our best to get back to you as soon as possible with a resolution to your issue.
I will appreciate your patience and  your understanding.
David
