Where can I find a 3D model for MPXAZ6115AP in package CASE1369
johnschimandle
Working on a PCB board blank drawing and need a 3D model for the MPXAZ6115AP pressure sensor. This sensor uses the package CASE1369 as specified on the data sheet. This is the right angle package with the barb connection.
Martin35804
You may find the 3D model in STEP format in Sensors Documents.
3D STEP model: SOP Top Side Port Package_1369-01
