What is the minimum excitation voltage for MPXV2102?
1,036件の閲覧回数
moranrp
The data sheet shows Vmin = "---", Vtyp = 10V and Vmax = 16V, and states that it is ratiometric within that range. Is there a minimum below which the output is no longer ratiometric? I.e., can I use a 3V supply?
タグ(1)
823件の閲覧回数
TomasVaverka
Hi Richard,
Yes, it is possible to use this sensor with a supply voltage less than 10V. Common min Vs is about 2 to 3V to get right ratiometric output.
Tomas
