I am in the process of purchasing PEMicro's U-MULTiLINK recorder, but the process is long and time-consuming. Can I use another recorder to record the firmware for the NTM88 sensor? I currently have the UM232H, would it be compatible?
I am not sure if NTM88 is compatible with UM232H, I do not have information about it, but you can check UM11227 This user manual describes the features, architecture, and programming model of the NTM88 family of devices.
