So a pretty vague question: Is there a specific way to temperature compensate for the MMA8452 accelerometer? Is there an application note for it?
Do you offer any chips with a temperature sensor embedded?
thanks
Solved! Go to Solution.
Hi Michael,
There is no specific way nor application note regarding the temperature compensation.
Usually no temperature calibration is needed, the zero-g level (offset) changes typically within ±0.15 mg/°C. If this represent a problem for your application, you can perform a simple two point calibration at two temperatures to compensate the TCOff.
Tomas
Hi Michael,
Tomas
