Sensor MPL3115A2
Sensor MPL3115A2
886 次查看
monikafuchsova
Sensor MPL3115A2 - Is it possible to solder this sensor in the vapor phase oven without sticking the hole in the sensors cover?
738 次查看
reyes
No, I would not recommend to solder the MPL3115A2 in the vapor phase oven without sticking the hole in the sensor cover because high humid and heat media have the potential to dissolve, or be absorbed by the gel and corrupt the die surface or lead to wire-bond breakage.
So, sealing the hole on the sensor with kapton tape is absolutely recommended.
Jose
