我买了一批MPL3115A2,但是不会采集,请问有STM32F103的采集程序吗
In order to test the MPL3115A2 I would strongly recommend using the following FRDMKL25-P3115 demo kit:
https://www.nxp.com/support/developer-resources/evaluation-and-development-boards/freedom-developmen...
Then using our STB-CE software you can easily evaluate sensor’s performance and communicate with it through the virtual serial port.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
