SPI API Definition of TWR-CM3120-EVM
1,330 次查看
sesc
Hello everyone!
I'm interested in the IO-Link capable TWR-CM3120-EVM board and would like to control it's included master stack with a micro controller using the SPI interface. The user guide (found at https://www.nxp.com/docs/en/user-guide/KTTWRCM3120UG.pdf ) mentions that this is possible with the right jumper settings.
Unfortunately, the guide does not specify the API to control it via SPI, nor does it mention if there is a different document describing it.
Is this information available or part of the delivery? I was not able to find information about this on the product page.
Thanks and best regards
Sebastian
1,061 次查看
TomasVaverka
Hi Sebastian,
The IO-Link stack source code as well as the API documentation is available from TEConcept, not from NXP, unfortunately.
Please contact them directly through this website:
https://www.teconcept.de/en/content/contact
Tomas
1,061 次查看
coord_investiga
Hello, i bought  TWR-CM3120-EVM board and i need the software for use it, but the link you gave on past october is not aviable, so could you help me to know where i can get it?.
Thank you in advance.
