Resolution for MPX5500 pressure transducer
gabrielsofrone
Hello!
I am interested in purchasing a pressure transducer, model MPX5500. I have found the technical sheet present at https://www.nxp.com/docs/en/data-sheet/MPX5500.pdf but unfortunately it does not mention the measurement resolution (in kPa) of the transducer. Where could I find this data?
Thank you!
guoweisun
You can refer to Sensitivity in datasheet :
