Hello israelfelix,
Thank you for using the NXP community.
As I mentioned, the interrupts can wake-up the device from any of the STOP modes.
I do recommend reviewing Table 26 from the document provided before for further information.
For example, you may consider the ADC conversion completed interrupt to wake up the device. You may also consider the periodic wake-up timer (PWU) generates a periodic interrupt to wake up the MCU from any of the STOP modes.
I hope this information helps.
David
