NTM88: convert X-axis acceleration values to 'Hz' instead of 'g'. how can i achieve this?
1,448件の閲覧回数
ankit2631
currently i am using GenFSK_Beacons example, i want to get acceleration values in terms of hertz rather than g. how can i do this?is there any example code where i can get the reference?
2 返答(返信)
1,438件の閲覧回数
ErikaC
Thank you for contacting us
First, a measure of compensated counts must be converted into common units and then convert to the unit of your choice, please see AN13614 NTM88 Sensor Measurements section 1.5 Converting compensated measurements into common units.
I am afraid we do not have an example code for reference
Hope this helps
1,433件の閲覧回数
ankit2631
Hello Erika,
I have gone through the document that you suggested but i have already implemented that conversion of raw values to common unit, i.e. in 'g'(m/s^2). But i want to convert this value to Hertz.
