NTM88 base circuit
NTM88 base circuit
899 次查看
leoaugustoam
What is the minimum circuit that I can use the ntm88? What scheme can I follow to validate the capture of pressure and temperature signals and send them via RF?
1 回复
870 次查看
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
I do recommend using the schematic attached as a reference for your design.
I hope this information helps.
David
