MPXM2053 Supply Voltage
heiko_dd
Can I use Vs = 5 VDC to supply the MPXM2053GS? The chosen instrumentation amplifier INA333 is made for 2.5 V common-mode voltage.
TomasVaverka
Hi Heiko,
Yes, it is possible to use this sensor with a supply voltage of 5V, the minimum Vs is about 3V to get right ratiometric output. The selected instrumentation amplifier should be OK.
Tomas
TomasVaverka
Hi Heiko,
Tomas
heiko_dd
Thanks!
