Dear Sir/Madam
One of our OEM customer wants to purchase MPXH6115A6U,but he told me someone quoted him MPXHZ6115A6U instead,he wants to know what is the difference between this two parts?
Does MPXHZ6115A6U and replace MPXH6115A6U?
Can you help to answer it?
Thank you very much!
Ada
ZD Components Trading.
Dear Susan,
The only difference is in the gel coat which protects the die and wire bonds. The MPXH6115A6U has a standard Fluorosilicon gel, while the MPXHZ6115A6U uses the Media Resistant gel more resistent to high humidity and common automotive media.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
