Hello!
I don’t understand what is the difference between these pressure sensors.
which is better?
Thank you.
MPX6115 and MPX4115 are very similar to each other in terms of functionality, both families are Integrated, compensated and calibrated sensors, both have the same pressure range up to 115kPa, same voltage input ranges and same output voltage ranges, difference is only that the MPX6115 is a newer family.
Jose
