MPX5700GP1 - 90degree lead form
Search instead for
I am interested in pressure sensor MPX5700GP1, which should have 90 degree lead form. Although, I have not found appropriate drawing. Does it look like in attached picture? (PrintScreen from Eagle). Crucial dimension is between mounting holes and soldering pads (marked in picture).
Thank you
Hi Szegi,
Attached you can find the requested drawing with the proper dimensions of the bended leads. I do not have tolerances for these, just the nominal values as measured by the factory.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
Am looking for MPX5700GP1 - Front and Back Picture of the original component to see whether the leads can be straighten to use.
Hi Szegi,
I hope it helps.
Tomas
