Offset errors are typically caused due to device to device offset variation (trim errors), mechanical stresses (mounting stresses), shifts due to temperature and aging.
Performing auto-zero helps to reduce these errors. Please have a look at our AN1636 “Implementing Auto-Zero for Integrated Pressure Sensors” for more detailed information about this topic.
BR, Tomas
Could you please translate your question into English and elaborate a bit more on your application with the MPX5700D?
BR, Tomas
MPX5700D pressure sensor chip was found abnormal absolute zero pressure value, want to know the normal test method.
BR, Tomas
