MPX5100AP mounting
MPX5100AP mounting
1,125 次查看
SeungYongShin
I'm currently using the MPX5100AP with 90degree bending the lead. The actual direction of the bending lead is the picture below.
I would like to know if there is risk of damage the wire bond to the die. If the lead can be bent to use, are there any carefully handle method when bending?
Thanks and regards,
SeungYong
1,094 次查看
guoweisun
Don't suggest your bending this pins.
