MPX5050 'Output vs Pressure' graph appears incorrect according to the transfer function?
matthewdoveton
I have modelled the sensor characteristics in Matlab using the given transfer function:
My plot does not match the datasheet plot for the Min/Max values:
I am using the transfer function given:
I'm unsure at this moment whether I am incorrect or the datasheet is. Can anyone confirm?
Thanks.
TomasVaverka
Hi Matthew,
Your calculation is correct, I have already asked the responsible team for correction. Sorry for any inconvenience this may caused.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
matthewdoveton
Thanks Tomas
