MPX5010DP - Output wiring question
1,441 次查看
coilino_toole
I'm trying to use the MPX5010DP sensor as a water level sensor and I'm running into a difficulty.  (This is not my area of expertise needless to say).
I have a 5V supply attached to Pin 3 (Vs) and the Ground connected to Pin 2.  I am reading the output from Pin 1 (Vout) and Pin 2 with the multimeter and it is very obviously not responding to changes in pressure across the barbs of the sensor.   I'm getting a reading of around 850mV that declines slowly over time.
What have I done wrong?  Many thanks for any assistance.
标记 (1)
1,153 次查看
coilino_toole
Hello again.  I have the problem sorted.  It was basically a bad connection on the multimeter.  The sensor is now working great.
1,153 次查看
TomasVaverka
Hi Coilin,
OK... good to know.
Tomas
