MPX2010DP calculate air flow
JeffChang
Dear Sir,
How to calculate air flow (kg/s) by below condition? Please kindly recommend, thank you
1. Pipe diameter:  6mm
2. Orifice diameter: 5mm
3. Pressure difference(get from MPX2010DP pressure sensor): 0.5 psi
JozefKozon
Dear Jeff,
I have found a link with formula and an explanation how to calculate the airflow of the air. Please see this link: https://allsensors.com/engineering-resources/white-papers/pressure-point-11-calculating-flow-rate-fr...
Also please see this link: Is Low Velocity Bad for Air Flow in Ducts? | Energy Vanguard
It might be also useful for you.
With Best Regards,
Jozef
JeffChang
Dear Jozef,
Thanks for you quick support.
