MPR03x PCB footprint dimensioned dwg.
onechil
I haven't been able to find a recommended PCB footprint drawing (with dimensions) for the MPR03x uDFN part. Could someone please refer me to one? Thanks!
Joshevelle
Senior Contributor I
Hello onechil,
Element 14 has a very useful library for Freescale devices and many other manufacturers. The MPR031EPR2 is listed in the Freescale_Library_Components_List.pdf
http://www.element14.com/community/docs/DOC-64263/l/freescale-cad-library-for-cadsoft-eagle-software
Unfortunately the format is not DWG, but both, the data sheet and the library, contains all the required information to easily create the specific drawing format that you're looking for.
Hope it helps.
-Josh
onechil
Thanks Josh - The element14 reference is a good foundation for me to work with.
