Good morning Team,
MMA8452QR1 is this obsolete component? If yes, any alternative options like-for-like available?
已解决! 转到解答。
Hello abialevich1,
I hope all is great with you. Thank you for using the NXP communities.
You are correct, the MMA8452Q device is obsolete. Unfortunately, we do not have a direct replacement. I mean, pin-to-pin compatible.
In this case, I would like to recommend the following series from our accelerometer portfolio:
FXLS8967AF - ±2g/±4g/±8g/±16g, Low Power 12-bit Digital Accelerometer
I hope this information helps.
David
Hello abialevich1,
David
Rochester Electronics has partnered with NXP Motion Sensor team to offer EOL products. We have acquired extensive authorized NXP inventory on MMA8452QR1/MMA8453Q1/MMA8451Q1. Please visit www.rocelec.com to view our extensive NXP Accelerometer inventory.
