I want to measure vacuum in a Tensiometer. Tensiometers are used in soil moisture measurement. The mechanical design uses a vacuum gage with a range of 0 to 100 centibar. Please suggest an appropriate device.
laxmankarandika
TomasVaverka
Hello Laxman,
Thank you for your interest in NXP pressure sensors.
I would recommend the MPXV6115V series designed to measure a negative gauge pressure. The datasheet is available here and you can buy it or order free samples from this website.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
laxmankarandika
Thank you, Tomas.
I have placed order for 5 samples.
warm regards,
L.S.Karandikar
laxmankarandika
Thank you, Tomas.
warm regards,
L.S.Karandikar
