Hello all,
As far as I know, the ADC results are kept in ACQ_CURR, ACQ_VOLT, and ACQ_ETEMP-ACQ_ITEMP registers in MM9Z1J638 intelligent battery sensor. However, when I connect the board to my computer via P&E's Universal Multilink and debug it, I cannot see what I expect as resultant ADC.
First of all, I connect board to my PC.
Then I debug the demo code.
Then I connect another voltage source to _NTC and NTC pins. Thus, I create a voltage difference which should be written into ACQ_ETEMP register. I change the voltage levels. But, the ADC result I see from "register view" of freescale's code warrior does not change. I tried to set PA7 of the MCU, when the adc result is greater than a value or less than some other value, I was not able to see any change on the oscilloscope which is connected to PA7 output pin.
How can I see that as I change the voltage level applied in between _NTC and NTC pins results in a change of ADC value which is kept in ACQ_ETEMP register.
Are there any other method to see the adc result? Why does it always end up with the same ADC result in ACQ_ETEMP register although I change the voltage difference in between _NTC and NTC pins? Similarly, when I apply some voltage difference in between Cell1- and Cell1+ for (Vsense channel) and when I change the difference, I do not see any change in ACQ_VOLT register. Again, I do not see why the register values in which ADC results are kept does not change.
I am looking forward to see your comments and advices.
Thanks in advance.
Solved! Go to Solution.
Hello David,
Sorry for late reply. I was not able to answer since I was out of my office. I have solved this register viewing problem. Thank you for your recommendations.
Hello David,
Hello Kadir,
My apologies for the delayed response.
Indeed, the current and the voltage results will be stored at the ACQ_CURR1 / ACQ_CURR0 and ACQ_VOLT registers.
Have you tried using the KIT9Z1J638EVM Demo Software?
The demo software has the following features:
You may download it from here.
I hope this information will be useful for you.
If I misunderstood your question, feel free to let me know. I will be glad to help.
Have a great day.
David Diaz.
Hello David,
