If the Magnetic field sensor(such as KMZ10A)has stopped production. How can I choose other magnetic field sensor to replace it.
Are there have some Selection parameters to choose sensor,such as Hy、Hx or sensitivity?
Or,are there have the substitute of KMZ10A?
Hi Jin,
The KMZ10A was a single bridge magnet field sensor, there is no 1 to 1 replacement in our portfolio. The most close one would be the KMZ41, but it is a double bridge sensor.
Tomas
