How to Find the transfer function of MPX5700AP
dengyong
     I can find the transfer function of differential pressure (kPa) in the datasheet,that is  Vout = VS*(0.0012858*P+0.04) ± Error . I think it is the transfer function of MPX5700DP . However I has applied MPX5700AP in my project, So Can you tell me how to find the transfer function of MPX5700AP.
     Thinks.
TomasVaverka
Hi Deng,
The transfer function for MPX5700 is correct and the same for both absolute and Diff/Gauge for their respective pressure ranges.  The absolute version is reference to a vacuum whereas the Diff/Gauge are reference to either another pressure reference or vented (atmosphere).
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
dengyong
I‘v get it.Thanks to Tomas!
TomasVaverka
Hi Deng,
Tomas
