Currently we do not offer a complete BTPS solution with a Bluetooth module allowing to send your tires' pressure e.g. to your smartphone or smartwatch.
In terms of a pressure sensor itself, I would recommend considering the MPxx6400A family of integrated analog pressure sensors with temperature compensation, calibration and amplifier circuitry on–chip. The output voltage for full rated pressure (400kPa) is typically 4.8V.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
